Einleitung
We will teach how to replace a faulty motherboard by severing its connection to the battery and removing it from the mounts.
Was du brauchst
Place one hand on the toothbrush handle and one on the toothbrush head.
Separate the toothbrush head from the body by twisting it in a counter-clockwise direction.
Insert the spudger along the seem at the top of the panel.
Begin to pry open the panel.
Insert the plastic pick at the top of the seam that has already been slightly pried open.
Continue down the seam, prying the rest of the panel open with the spudger.
Apply a soldering iron to the mount-connectors and copper-wire connectors until the motherboard can be removed.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Identification of the battery particulars would have been helpful to order replacement.
