Einleitung
To enter the housing of the handle of the toothbrush, the first step is to remove the back panel. We will be explaining how to pry off the panel to access the other parts inside.
Was du brauchst
Place one hand on the toothbrush handle and one on the toothbrush head.
Separate the toothbrush head from the body by twisting it in a counter-clockwise direction.
Insert the spudger along the seem at the top of the panel.
Begin to pry open the panel.
Insert the plastic pick at the top of the seam that has already been slightly pried open.
Continue down the seam, prying the rest of the panel open with the spudger.
Eine weitere Person hat diese Anleitung absolviert.
