Zum Hauptinhalt wechseln
Philips TAS7505 Outer Shell Disassembly
Was du brauchst
  1. Philips TAS7505 Outer Shell Disassembly, Philips TAS7505 Outer Shell Disassembly: Schritt 1, Bild 1 von 2 Philips TAS7505 Outer Shell Disassembly, Philips TAS7505 Outer Shell Disassembly: Schritt 1, Bild 2 von 2
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
    Frag FixBot
  2. Philips TAS7505 Outer Shell Disassembly: Schritt 2, Bild 1 von 3 Philips TAS7505 Outer Shell Disassembly: Schritt 2, Bild 2 von 3 Philips TAS7505 Outer Shell Disassembly: Schritt 2, Bild 3 von 3
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
    Frag FixBot
  3. Philips TAS7505 Outer Shell Disassembly: Schritt 3, Bild 1 von 3 Philips TAS7505 Outer Shell Disassembly: Schritt 3, Bild 2 von 3 Philips TAS7505 Outer Shell Disassembly: Schritt 3, Bild 3 von 3
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
    Frag FixBot
  4. Philips TAS7505 Outer Shell Disassembly: Schritt 4, Bild 1 von 3 Philips TAS7505 Outer Shell Disassembly: Schritt 4, Bild 2 von 3 Philips TAS7505 Outer Shell Disassembly: Schritt 4, Bild 3 von 3
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
    Frag FixBot
  5. Philips TAS7505 Outer Shell Disassembly: Schritt 5, Bild 1 von 1
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
    Frag FixBot
Abschluss
CSU Los Angeles, Team 5-2, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 5-2, Adachi Fall 2022
CSULA-ADACHI-F22S5G2
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 61
Insgesamt: 1,170
