Einleitung
This guide will show you how to remove and replace a dead battery.
Was du brauchst
Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
Use plastic opening tool to pry off back plate.
Move the plastic opening tool along the the device to further pry open the device.
Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
In this step you will perform the soldering to remove the positive(red) and negative(black) wires).
Once the solder is removed your battery is now removed and can be replaced with the new battery.
2 Kommentare
Battery Replacement of the Photove Loudspeaker PH-BTW55
A very good description and easy to do, but: to replace a Battery to have to use a soldering iron is behind every tecnologie - must be „Made in China". Would I have know this on the first place I never would have bought this and I never will!
