Einleitung
Does the audio coming from your device sound rough? Does your device not emit any audio and you've ruled out the battery or the volume as the cause? Then the speaker may be the problem. This guide goes through the steps necessary to remove the speaker from your Photive Rain device so you can replace the speaker.
Was du brauchst
Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
Remove back panel
Detach the connector clips from the motherboard using the iFixit Opening Tool.
Some force may be necessary to remove the plastic clips.
After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
2 weitere Personen haben diese Anleitung absolviert.
