Zum Hauptinhalt wechseln
Pickleball Racket Grip Tape Replacement
Was du brauchst
  1. Pickleball Racket Grip Tape Replacement, Grip Tape: Schritt 1, Bild 1 von 3 Pickleball Racket Grip Tape Replacement, Grip Tape: Schritt 1, Bild 2 von 3 Pickleball Racket Grip Tape Replacement, Grip Tape: Schritt 1, Bild 3 von 3
    • Remove the previous grip — start with the grip band and electrical tape at the top, then peel all the way down.
  2. Pickleball Racket Grip Tape Replacement: Schritt 2, Bild 1 von 2 Pickleball Racket Grip Tape Replacement: Schritt 2, Bild 2 von 2
    • Clean the handle with cleansing wipes or by pulling the sticky residue off of the handle.
  3. Pickleball Racket Grip Tape Replacement: Schritt 3, Bild 1 von 3 Pickleball Racket Grip Tape Replacement: Schritt 3, Bild 2 von 3 Pickleball Racket Grip Tape Replacement: Schritt 3, Bild 3 von 3
    • Peel off the adhesive strip on the back of the end of the tape, then apply it flush to the bottom of the paddle handle.
  4. Pickleball Racket Grip Tape Replacement: Schritt 4, Bild 1 von 2 Pickleball Racket Grip Tape Replacement: Schritt 4, Bild 2 von 2
    • Start wrapping the tape around the paddle handle upwards and diagonally.
    • Maintain tension throughout the entire process, but don’t pull too tight as to stretch the grip.
  5. Pickleball Racket Grip Tape Replacement: Schritt 5, Bild 1 von 2 Pickleball Racket Grip Tape Replacement: Schritt 5, Bild 2 von 2
    • Cut from the bottom of the tape to the top at a shallow angle, then finish wrapping the tape around the shaft of the paddle.
  6. Pickleball Racket Grip Tape Replacement: Schritt 6, Bild 1 von 3 Pickleball Racket Grip Tape Replacement: Schritt 6, Bild 2 von 3 Pickleball Racket Grip Tape Replacement: Schritt 6, Bild 3 von 3
    • Add about a half-inch-wide strip of electrical tape to the top of the handle to hold everything in place and cover with the grip band.
Ziellinie
Evelyn Zacks
133 Reputation
1 Anleitung geschrieben
UC Davis, Team 2-5, Whithaus Spring 2025 Mitglied von UC Davis, Team 2-5, Whithaus Spring 2025
UCD-WHITHAUS-S25S2G5
2 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 160
