Zum Hauptinhalt wechseln
Picture Frame Matting Replacement
Was du brauchst
  1. Picture Frame Matting Replacement, Picture Frame Matting: Schritt 1, Bild 1 von 1
    • Place the picture frame face down on a clean surface.
  2. Picture Frame Matting Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to rotate all of the frame’s backing clips away from the frame.
  3. Picture Frame Matting Replacement: Schritt 3, Bild 1 von 2 Picture Frame Matting Replacement: Schritt 3, Bild 2 von 2
    • Remove the backing by lifting it up and away using a spudger.
  4. Picture Frame Matting Replacement: Schritt 4, Bild 1 von 1
    • Carefully remove the picture and old matting from the frame.
    • You can leave the glass in the frame.
  5. Picture Frame Matting Replacement: Schritt 5, Bild 1 von 1
    • Place the new matting into the frame and directly onto the glass.
    • Be careful while working around the glass to avoid self-injury or damaging the item.
  6. Picture Frame Matting Replacement: Schritt 6, Bild 1 von 2 Picture Frame Matting Replacement: Schritt 6, Bild 2 von 2
    • Position the picture properly and place it on the new matting.
    • Make sure there are no gaps between the edge of the picture and the matting.
    • Carefully place a couple of small pieces of clear tape on the picture and the new matting to hold it in place.
  7. Picture Frame Matting Replacement: Schritt 7, Bild 1 von 1
    • Place the backing on top of the matting in the frame.
  8. Picture Frame Matting Replacement: Schritt 8, Bild 1 von 2 Picture Frame Matting Replacement: Schritt 8, Bild 2 von 2
    • Rotate the backing clips under the frame to secure it.
Ziellinie
Leah
160 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 172
