Zum Hauptinhalt wechseln
Pine64 PinePhone Front and Rear Camera Replacement
Was du brauchst
  1. Pine64 PinePhone Front and Rear Camera Replacement, Back Cover: Schritt 1, Bild 1 von 2 Pine64 PinePhone Front and Rear Camera Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Front and Rear Camera Replacement: Schritt 2, Bild 1 von 1
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Front and Rear Camera Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using a fingernail, press into the bottom divot and remove the battery from the phone.
  4. Pine64 PinePhone Front and Rear Camera Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Use a spudger or plastic opening tool to pry off the plastic cover.
  5. Pine64 PinePhone Front and Rear Camera Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger to lift the ZIF tabs and press-fit connectors free.
  6. Pine64 PinePhone Front and Rear Camera Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger to lift the motherboard up and remove it from the device.
  7. Pine64 PinePhone Front and Rear Camera Replacement, Front and Rear Camera: Schritt 7, Bild 1 von 1
    • Use a spudger to remove the rear camera.
  8. Pine64 PinePhone Front and Rear Camera Replacement: Schritt 8, Bild 1 von 1
    • Use a spudger to remove the front camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 20
Insgesamt: 341
