Einleitung
If you need to replace the front mesh on your Pioneer A1 XW-SMA1-K speaker this guide will explain you how to remove the front cover using the iFixit spudger. This shows how to properly remove the front panel so that you can clean it or replace it.
Was du brauchst
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
