Zum Hauptinhalt wechseln
Pioneer A1 XW-SMA1-K Motherboard Replacement
Was du brauchst
  1. Pioneer A1 XW-SMA1-K Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Use the spudger to remove the mesh front panel.
  2. Pioneer A1 XW-SMA1-K Motherboard Replacement: Schritt 2, Bild 1 von 2 Pioneer A1 XW-SMA1-K Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
    • Remove the speaker frame by pulling vertically upwards revealing the motherboard.
  3. Pioneer A1 XW-SMA1-K Motherboard Replacement: Schritt 3, Bild 1 von 3 Pioneer A1 XW-SMA1-K Motherboard Replacement: Schritt 3, Bild 2 von 3 Pioneer A1 XW-SMA1-K Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
    • Remove the middle frame by pulling upward and vertically.
  4. Pioneer A1 XW-SMA1-K Motherboard Replacement: Schritt 4, Bild 1 von 2 Pioneer A1 XW-SMA1-K Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
    • Flip the motherboard over.
    • Remove the motherboard by detaching the antenna.
  5. Pioneer A1 XW-SMA1-K Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove the motherboard from the speaker.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 22
Insgesamt: 582
