Einleitung
If you are encountering the motherboard of this speaker, these will be the steps of taking it apart.
Was du brauchst
Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
Remove the speaker frame by pulling vertically upwards revealing the motherboard.
Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
Remove the middle frame by pulling upward and vertically.
Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
Flip the motherboard over.
Remove the motherboard by detaching the antenna.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
