Einleitung
Overheating can cause the Pioneer Elite PRO-R06U to unexpectedly shut off during operation. A broken
cooling fan will make it difficult for the media receiver to dissipate heat, and is the most likely cause of overheating. This guide will show you how to replace the power supply cooling fan.
Was du brauchst
Remove the two 6.4 mm Phillips screws on each side of the device's casing.
Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
To replace the back cooling fan, grip the ribbon connector at slot M10 and remove by gently pulling upward.
Grip the frame of the cooling fan and slide away from the back wall until the tabs are no longer in the holes of the casing.
Lift the cooling fan out of the device.
