Zum Hauptinhalt wechseln
Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement
Was du brauchst
  1. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement, Optical Drive Cooling Fan: Schritt 1, Bild 1 von 1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: Schritt 4, Bild 1 von 1
    • To replace the optical drive cooling fan, grip the ribbon connector at M11 and gently remove by pulling away for the slot.
  5. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: Schritt 5, Bild 1 von 1
    • Flip the latch on the ribbon connector upward to allow for cable removal.
    • Grip the ribbon cable and remove by gently pulling away from the unlatched connector.
  6. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 6.4 mm Phillips mounting screws on the optical drive cooling fan.
  7. Pioneer Elite PRO-RO6U Optical Drive Cooling Fan Replacement: Schritt 7, Bild 1 von 1
    • Grip the frame of the cooling fan and slide it toward the front panel, then lift out of the device.
Abschluss
Cody Carter
1.049 Reputation
6 Anleitungen geschrieben
Baylor, Team S1-G5, Johnson Spring 2018 Mitglied von Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 247
