Zum Hauptinhalt wechseln
Pioneer Elite PRO-RO6U Power Supply Board Replacement
Was du brauchst
  1. Pioneer Elite PRO-RO6U Power Supply Board Replacement, Power Supply Board: Schritt 1, Bild 1 von 1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Power Supply Board Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Power Supply Board Replacement: Schritt 3, Bild 1 von 1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Power Supply Board Replacement: Schritt 4, Bild 1 von 1
    • Gently pull upward and unplug cables D4 and D5.
  5. Pioneer Elite PRO-RO6U Power Supply Board Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 7/16 inch Phillips screws to the left and right of the power supply port.
    • Remove three 5/16 inch Phillips screws from the corners of the board.
  6. Pioneer Elite PRO-RO6U Power Supply Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the power supply board by pulling it toward the interior of the device then lifting.
Abschluss
Cody Carter
1.049 Reputation
6 Anleitungen geschrieben
Baylor, Team S1-G5, Johnson Spring 2018 Mitglied von Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 590
