Zum Hauptinhalt wechseln
Pioneer FH-X730BS Auxiliary Inlet Replacement
Was du brauchst
  1. Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: Schritt 1, Bild 1 von 3 Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: Schritt 1, Bild 2 von 3 Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: Schritt 1, Bild 3 von 3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS Auxiliary Inlet Replacement: Schritt 2, Bild 1 von 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: Schritt 2, Bild 2 von 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: Schritt 2, Bild 3 von 3
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Pioneer FH-X730BS Auxiliary Inlet Replacement: Schritt 3, Bild 1 von 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: Schritt 3, Bild 2 von 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: Schritt 3, Bild 3 von 3
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Pioneer FH-X730BS Auxiliary Inlet Replacement, Auxiliary Inlet: Schritt 4, Bild 1 von 1
    • Here you are able to desolder the auxiliary ports from the circuit board and solder a replacement auxiliary port on.
    • The end of the soldering iron will be hot.
Abschluss
Cody Pesta
688 Reputation
6 Anleitungen geschrieben
Washington State, Team S2-G4, Hope Fall 2018 Mitglied von Washington State, Team S2-G4, Hope Fall 2018
WSU-HOPE-F18S2G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 171
