Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
A faulty auxiliary inlet can cause the user unable to play media to the radio receiver. This guide will show you how to replace the Auxiliary Inlet for the Pioneer FH-X730BS.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Apply pressure to the tabs on each side using the plastic opening tool. You will need to pull the face away from the frame while unhooking the tabs. You will need to pull the face away from the frame while unhooking the tabs.
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. After removing the stereo face from the frame it should look similar to this. Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face. Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Remove the volume knob by pulling it towards you and pull the motherboard out of the face. The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons. You can now insert the replacement audio buttons into the face.
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  5. Here you are able to desolder the auxiliary ports  from the circuit board and solder a replacement auxiliary port on.
    • Here you are able to desolder the auxiliary ports from the circuit board and solder a replacement auxiliary port on.
    • The end of the soldering iron will be hot.
Abschluss
Cody Pesta
667 Reputation
6 Anleitungen geschrieben
Washington State, Team S2-G4, Hope Fall 2018 Mitglied von Washington State, Team S2-G4, Hope Fall 2018
WSU-HOPE-F18S2G4
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 60
