Einleitung
A broken disk drive can cause the user unable to play CDs on the radio receiver. This guide will show you how to replace the disk drive for the Pioneer FH-X730BS.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Apply pressure to the tabs on each side using the plastic opening tool. You will need to pull the face away from the frame while unhooking the tabs. You will need to pull the face away from the frame while unhooking the tabs.
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. After removing the stereo face from the frame, it should look similar to this.
    • After removing the stereo face from the frame, it should look similar to this.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Du bist ein Genie!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
    • Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
  5. Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame. Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame. Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
    • Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
  6. Unscrew the four  inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate. Replace the old disk drive with a new one. Replace the old disk drive with a new one.
    • Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
    • Replace the old disk drive with a new one.
Abschluss
Cody Pesta
667 Reputation
6 Anleitungen geschrieben
Washington State, Team S2-G4, Hope Fall 2018 Mitglied von Washington State, Team S2-G4, Hope Fall 2018
WSU-HOPE-F18S2G4
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 44
