Einleitung
A broken disk drive can cause the user unable to play CDs on the radio receiver. This guide will show you how to replace the disk drive for the Pioneer FH-X730BS.
Was du brauchst
Apply pressure to the tabs on each side using the plastic opening tool.
You will need to pull the face away from the frame while unhooking the tabs.
Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
Replace the old disk drive with a new one.
