Zum Hauptinhalt wechseln
Pioneer R1 Battery Replacement
Was du brauchst
  1. Pioneer R1 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert your plastic spudger into the opening near the HDMI port.
    • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
    • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
  2. Pioneer R1 Battery Replacement: Schritt 2, Bild 1 von 1
    • Lay the R1 flat like an open book.
    • This will prevent the speakers from becoming disconnected from the motherboard.
  3. Pioneer R1 Battery Replacement: Schritt 3, Bild 1 von 1
    • Slide a strong thin object, like a thin spudger, between the battery and the display.
    • Slide the object along the length of the battery to remove it from the display.
    • The adhesive holding the battery in place is strong and the battery is quite soft. Take care not to break open the battery.
    • Disengage the battery cables from the motherboard.
  4. Pioneer R1 Battery Replacement: Schritt 4, Bild 1 von 1
    • Solder the black cable to the nodule labeled BAT+.
    • Solder the red cable to the nodule labeled BAT-.
    • Do not allow the solder from one nodule to touch the other, this may cause the battery to explode.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
San Diego State, Team 1-1, Sheppard Winter 2015 Mitglied von San Diego State, Team 1-1, Sheppard Winter 2015
SDSU-SHEPPARD-W15S1G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 774
