Einleitung
This guide will demonstrate how to access and replace the R1's battery.
Was du brauchst
Insert your plastic spudger into the opening near the HDMI port.
Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
Slide a strong thin object, like a thin spudger, between the battery and the display.
Slide the object along the length of the battery to remove it from the display.
Disengage the battery cables from the motherboard.
Solder the black cable to the nodule labeled BAT+.
Solder the red cable to the nodule labeled BAT-.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
