Einleitung
This guide will walk you through the process of accessing and replacing your R1's touch screen/digitizer.
Was du brauchst
Insert your plastic spudger in the opening near the HDMI port.
Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
Remove the tape that is holding the motherboard to the display and covering the cable attachments.
Peel back just the end of this tape to free the front facing camera.
Remove the three 4 mm screws along the base of the motherboard with a Phillips #00 Screwdriver.
Disengage the two cable locks using your spudger or your finger nail.
Slide the cable free from the disengaged lock.
Insert your spudger between the LCD display and the touch screen.
Gently pry the LCD display from the the touchscreen by using the spudger along the edges.
