Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Pioneer SE-C8BT Bluetooth Headphones zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Unboxing: Schritt 1, Bild 1 von 2 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Unboxing: Schritt 1, Bild 2 von 2
    • Well we spected some confetti and ballons at time to opening this box but isn't that much.
    • In the box: A Micro USB Cable, Two pairs of gummies, Portable Case and Battery Charger and obviusly two pair of bluetooth Headphones :)
  2. Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Taking some rubbers apart: Schritt 2, Bild 1 von 3 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Taking some rubbers apart: Schritt 2, Bild 2 von 3 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Taking some rubbers apart: Schritt 2, Bild 3 von 3
    • First remove the gummy parts like the "dust" cover.
    • Now time to work in this one (you can choose L or R Headphone) they're the same in the outside at least :)
  3. Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Taking apart: Schritt 3, Bild 1 von 3 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Taking apart: Schritt 3, Bild 2 von 3 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Taking apart: Schritt 3, Bild 3 von 3
    • Using a Xacto or a Cutter horizontally press a little bit the the union of both plastics (Glued together).
    • Please be pathient cause it depends if your headphones conserves the "anti dust and waterproof" protection.
  4. Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Let' see what we got: Schritt 4, Bild 1 von 3 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Let' see what we got: Schritt 4, Bild 2 von 3 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Let' see what we got: Schritt 4, Bild 3 von 3
    • As you can see this is the 1.0 Version, how cute.
    • There are some test points to find out whats the problem: BATT (For to check the Battery votage is present and how much is it), 5V USB Power Supply, SDA & SCL Communication Points, and a RESET Piont (Maybe with a Pull Up push button resistor circuit).
    • An Elecetrolytic Microphone (Note: this one is into each bluetooth buddy).
    • The brain is open: Airoha AB1524 Truly Wireless Bluetooth IC.
    • Battery Cables Positive, Negative, and Sense.
    • LP & LN Speaker Connection (those speakers are inside the tube) very small... and unpower.
    • A very Small 55mAh LiPo Battery.
  5. Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Let's see what we got 2: Schritt 5, Bild 1 von 3 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Let's see what we got 2: Schritt 5, Bild 2 von 3 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Let's see what we got 2: Schritt 5, Bild 3 von 3
    • Now it's time to the Right Channel Buddie, same process, and alittle bit different PCB Main.
    • On the Top: An Electrolytic Microphone, Antenna Connection (is located on the borders glued and part of the case), an push button and test points with no info.
    • Upside down: Airoha AB1524 IC, Leds, Battery cables, RP & RN Speaker Connections and some passive electronic components.
    • Kola Loka (If you know you know)...
  6. Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Back in time: Schritt 6, Bild 1 von 2 Pioneer SE-C8BT Truly Wireless Bluetooth Headphones, Back in time: Schritt 6, Bild 2 von 2
    • Apply a little bit of amount of Kola Loka (using the point of a needle) on the circumference of the earphone and glue them. apply force while it dry.
Erik MV
265 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 350
