Einleitung
This guide will show you the steps to remove the drivers from the ear cups.
Was du brauchst
Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
With force, pull upwards.
Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
Repeat on the opposite side and the headband will be released.
While holding the base of the ear cup with one hand, insert your index finger from your other hand into the inside of the foam ear piece.
With slight force, peel the foam ear pieces away from the ear cup.
Repeat for the opposite side if necessary.
Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
