Zum Hauptinhalt wechseln
Pioneer Steel Wheels Headphone Headband Replacement
Was du brauchst
  1. Pioneer Steel Wheels Headphone Headband Replacement, Headband: Schritt 1, Bild 1 von 2 Pioneer Steel Wheels Headphone Headband Replacement, Headband: Schritt 1, Bild 2 von 2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Headphone Headband Replacement: Schritt 2, Bild 1 von 2 Pioneer Steel Wheels Headphone Headband Replacement: Schritt 2, Bild 2 von 2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Headphone Headband Replacement: Schritt 3, Bild 1 von 3 Pioneer Steel Wheels Headphone Headband Replacement: Schritt 3, Bild 2 von 3 Pioneer Steel Wheels Headphone Headband Replacement: Schritt 3, Bild 3 von 3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
Abschluss
Cal Poly, Team 10-40, Amido Spring 2013 Mitglied von Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Mitglieder
37 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 1,177
