Zum Hauptinhalt wechseln
Pipo Smart S1 Battery Replacement
Was du brauchst
  1. Pipo Smart S1 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Pipo Smart S1 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Pipo Smart S1 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Insert an iFixit opening tool between the body and display of the tablet at the bottom of the device where the charging port is.
    • Slide the tool along the gap you are creating, moving to the right direction against the mini USB port.
  2. Pipo Smart S1 Battery Replacement: Schritt 2, Bild 1 von 1
    • Gently pry the body of the tablet and pop the back cover open.
    • Lift the back cover of the device and place it on the side.
  3. Pipo Smart S1 Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift the edge of the white tape with the iFixit opening tool.
  4. Pipo Smart S1 Battery Replacement: Schritt 4, Bild 1 von 2 Pipo Smart S1 Battery Replacement: Schritt 4, Bild 2 von 2
    • Lift the white tape with your fingers, then lift the yellow tape that holds the battery extension.
  5. Pipo Smart S1 Battery Replacement: Schritt 5, Bild 1 von 1
    • On the bottom of your tablet, use the Phillips #0 screwdriver to take the two 3mm screws out.
  6. Pipo Smart S1 Battery Replacement: Schritt 6, Bild 1 von 2 Pipo Smart S1 Battery Replacement: Schritt 6, Bild 2 von 2
    • Lift the headphone jack and move it to the other side, placing it on the surface you are working on.
  7. Pipo Smart S1 Battery Replacement: Schritt 7, Bild 1 von 2 Pipo Smart S1 Battery Replacement: Schritt 7, Bild 2 von 2
    • Use a spudger to pry the battery and detach it from the glue underneath it.
    • Be careful not to pinch the battery—lithium batteries are hazardous and prone to short circuiting, and thus burning and/or exploding.
  8. Pipo Smart S1 Battery Replacement: Schritt 8, Bild 1 von 1
    • Lift the battery and place it a little further away from the positive and negative battery wires.
  9. Pipo Smart S1 Battery Replacement: Schritt 9, Bild 1 von 1
    • Using your soldering iron, melt the two lead spots to detach the wires.
    • The soldering iron is extremely hot, so handle with caution. Always keep the soldering iron holder next to you when using it so you can return it easily.
    • When reassembling, make sure you solder the right pole to the right spot on the circuit board, as swapping them can burn the motherboard.
  10. Pipo Smart S1 Battery Replacement: Schritt 10, Bild 1 von 2 Pipo Smart S1 Battery Replacement: Schritt 10, Bild 2 von 2
    • Remove the two wires. Then remove the battery completely from the device.
    • Make sure you tape the negative and positive battery wires to keep them from short-circuiting.
Abschluss
Ali Alqallaf
340 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 3-6, Passmore Fall 2016 Mitglied von USF Tampa, Team 3-6, Passmore Fall 2016
USFT-PASSMORE-F16S3G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 983
