Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Removing the grip panels allows you to change the battery and allows you to remove the frame, which gives access to more parts of the marker.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the 5/64" hex key to remove the screw shown. Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  3. Flip the marker over and use the 5/64" hex key to remove the screw shown.
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  4. Carefully remove the 9V battery and connector. Remove the 9V battery from the connector.
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jared Olson
211 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 10-42, Amido Fall 2014 Mitglied von Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 827
