Einleitung
Sometimes, the O-ring seals in the Etha's bolt can get worn out and need to be replaced. Fortunately, Planet Eclipse designed this part of the marker to be taken apart and put back together with ease.
Was du brauchst
Using the 1/4" hex key, turn the bolt counterclockwise and remove.
Grab the flat surface shown.
Unscrew this portion counter clockwise to remove it.
Grab the O-ring on the sides.
Pinch the O-ring upwards to create a gap between the metal and the ring.
Use a small object to slip into the loop and pull the O-ring off gently.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
