Einleitung
The Etha's Eyes determine there is a ball in the chamber before firing. This guide is useful for players who choose to upgrade their eyes, or for players who have a marker with broken eyes.
Was du brauchst
Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
Use the 5/64" hex key to remove the screw shown.
Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
Flip the marker over and use the 5/64" hex key to remove the screw shown.
Carefully remove the 9V battery and connector.
Remove the 9V battery from the connector.
Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
Use the 5/64" hex key to turn the screw counterclockwise.
Carefully remove the screw and place it off to the side.
Remove the panel and place it off to the side.
Carefully flip the marker over.
Remove the screw and place it off to the side.
Carefully remove the panel and place it off to the side.
Grip the marker with one hand and gently pull the eyes out with your other hand.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
