Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The Etha's Eyes determine there is a ball in the chamber before firing. This guide is useful for players who choose to upgrade their eyes, or for players who have a marker with broken eyes.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun. Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Remove the regulator by unscrewing it in a clockwise direction. Remove the regulator by unscrewing it in a clockwise direction.
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Use the 5/64" hex key to remove the screw shown. Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Flip the marker over and use the 5/64" hex key to remove the screw shown.
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Carefully remove the 9V battery and connector. Remove the 9V battery from the connector.
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  7. Carefully disconnect the three connectors from the circuit board. Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  8. Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise. Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  9. Be very careful during the step to avoid damage to the solenoid or wiring.
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
  10. Use the 5/64" hex key to turn the screw counterclockwise. Carefully remove the screw and place it off to the side.
    • Use the 5/64" hex key to turn the screw counterclockwise.
    • Carefully remove the screw and place it off to the side.
    • Remove the panel and place it off to the side.
  11. Carefully flip the marker over. Use the 5/64" hex key to turn the screw counterclockwise.
    • Carefully flip the marker over.
    • Remove the screw and place it off to the side.
    • Carefully remove the panel and place it off to the side.
  12. Grip the marker with one hand and gently pull the eyes out with your other hand. Grip the marker with one hand and gently pull the eyes out with your other hand.
    • Grip the marker with one hand and gently pull the eyes out with your other hand.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Hannah Lancaster
132 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-42, Amido Fall 2014 Mitglied von Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 9
Insgesamt: 830
