Einleitung
The solenoid valve is critical to operation and if it breaks or becomes unreliable, the marker will not function. This guide shows how to replace the solenoid in the event of failure.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
Use the 5/64" hex key to remove the screw shown.
Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
Flip the marker over and use the 5/64" hex key to remove the screw shown.
Carefully remove the 9V battery and connector.
Remove the 9V battery from the connector.
Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
Remove the two black hex bolts that connect the solenoid mount to the body.
Use the 5/64" Allen Key to rotate each screw counter clockwise.
Remove the two Phillips head screws that connect the solenoid to its mount.
Use a Phillip's head screwdriver and rotate each screw counter clockwise.
2 Kommentare
Watis the price on etha solenoid, where can i get one , l ma staying in SA, myne is leaking ear,email ratgonefishing @gmail. Com
Hi my etha solenoid leaks ear,where do l get one,wats the price,i m staying in SA
