Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The trigger on the Etha doesn't break often, but you may choose to replace it for a trigger you prefer or it may simply need cleaning.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the 5/64" hex key to remove the screw shown. Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Flip the marker over and use the 5/64" hex key to remove the screw shown.
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  4. Carefully remove the 9V battery and connector. Remove the 9V battery from the connector.
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  5. Use a hex key to unscrew the middle screw on the top of the trigger.
    • Use a hex key to unscrew the middle screw on the top of the trigger.
  6. Use same hex key to push through trigger retention pin on the side of the gun.
    • Use same hex key to push through trigger retention pin on the side of the gun.
  7. Pull out the trigger by grabbing the bottom and slowly rotating outwards. Pull out the trigger by grabbing the bottom and slowly rotating outwards.
    • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Evan Hench
211 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-42, Amido Fall 2014 Mitglied von Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 668
