Zum Hauptinhalt wechseln
Planet Eclipse Geo3 Eyes Replacement
Was du brauchst
  1. Planet Eclipse Geo3 Eyes Replacement, Grip: Schritt 1, Bild 1 von 2 Planet Eclipse Geo3 Eyes Replacement, Grip: Schritt 1, Bild 2 von 2
    • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  2. Planet Eclipse Geo3 Eyes Replacement: Schritt 2, Bild 1 von 2 Planet Eclipse Geo3 Eyes Replacement: Schritt 2, Bild 2 von 2
    • Pull the grip away from the frame.
  3. Planet Eclipse Geo3 Eyes Replacement: Schritt 3, Bild 1 von 2 Planet Eclipse Geo3 Eyes Replacement: Schritt 3, Bild 2 von 2
    • Pull the grip through the opening.
    • The grip is connected in the middle and is one piece.
  4. Planet Eclipse Geo3 Eyes Replacement, Macroline: Schritt 4, Bild 1 von 3 Planet Eclipse Geo3 Eyes Replacement, Macroline: Schritt 4, Bild 2 von 3 Planet Eclipse Geo3 Eyes Replacement, Macroline: Schritt 4, Bild 3 von 3
    • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
  5. Planet Eclipse Geo3 Eyes Replacement: Schritt 5, Bild 1 von 3 Planet Eclipse Geo3 Eyes Replacement: Schritt 5, Bild 2 von 3 Planet Eclipse Geo3 Eyes Replacement: Schritt 5, Bild 3 von 3
    • While pulling in the metal ring on the fitting, pull the macroline out.
  6. Planet Eclipse Geo3 Eyes Replacement, Body: Schritt 6, Bild 1 von 3 Planet Eclipse Geo3 Eyes Replacement, Body: Schritt 6, Bild 2 von 3 Planet Eclipse Geo3 Eyes Replacement, Body: Schritt 6, Bild 3 von 3
    • Use 1/8" allen wrench to remove screw behind regulator.
  7. Planet Eclipse Geo3 Eyes Replacement: Schritt 7, Bild 1 von 3 Planet Eclipse Geo3 Eyes Replacement: Schritt 7, Bild 2 von 3 Planet Eclipse Geo3 Eyes Replacement: Schritt 7, Bild 3 von 3
    • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
    • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
    • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
  8. Planet Eclipse Geo3 Eyes Replacement, Eyes: Schritt 8, Bild 1 von 3 Planet Eclipse Geo3 Eyes Replacement, Eyes: Schritt 8, Bild 2 von 3 Planet Eclipse Geo3 Eyes Replacement, Eyes: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a prying tool or tweezers to gently remove the connection from the board. It is the connection with 2 black and 2 red wires.
    • Pull the wire through the opening.
  9. Planet Eclipse Geo3 Eyes Replacement: Schritt 9, Bild 1 von 3 Planet Eclipse Geo3 Eyes Replacement: Schritt 9, Bild 2 von 3 Planet Eclipse Geo3 Eyes Replacement: Schritt 9, Bild 3 von 3
    • Use 5/64" allen key to remove each screw from eye covers (Located on both sides of the paintball marker.)
    • Pull off eye covers. (Located on both sides of the paintball marker.)
  10. Planet Eclipse Geo3 Eyes Replacement: Schritt 10, Bild 1 von 3 Planet Eclipse Geo3 Eyes Replacement: Schritt 10, Bild 2 von 3 Planet Eclipse Geo3 Eyes Replacement: Schritt 10, Bild 3 von 3
    • Gently pull out the two eyes, one on each side of the paintball marker.
    • The red wire leading to the eye on the right side of the paintball marker. The black wire leads to the eye on the left side.
Abschluss
To reassemble your device with a new eye wire, follow this guide in reverse.
Rett Triplett
801 Reputation
8 Anleitungen geschrieben
Clemson, Team 13-6, Benson Fall 2013 Mitglied von Clemson, Team 13-6, Benson Fall 2013
CLEM-BENSON-F13S13G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,106
