Einleitung
This guide will show how to replace the eyes and eye wire if either are damaged.
Was du brauchst
Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
Pull the grip through the opening.
The grip is connected in the middle and is one piece.
Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
Use a prying tool or tweezers to gently remove the connection from the board. It is the connection with 2 black and 2 red wires.
Pull the wire through the opening.
Use 5/64" allen key to remove each screw from eye covers (Located on both sides of the paintball marker.)
Pull off eye covers. (Located on both sides of the paintball marker.)
To reassemble your device with a new eye wire, follow this guide in reverse.
