Zum Hauptinhalt wechseln
Planet Eclipse Geo3 Solenoid Replacement
Was du brauchst
  1. Planet Eclipse Geo3 Solenoid Replacement, Grip: Schritt 1, Bild 1 von 2 Planet Eclipse Geo3 Solenoid Replacement, Grip: Schritt 1, Bild 2 von 2
    • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  2. Planet Eclipse Geo3 Solenoid Replacement: Schritt 2, Bild 1 von 2 Planet Eclipse Geo3 Solenoid Replacement: Schritt 2, Bild 2 von 2
    • Pull the grip away from the frame.
  3. Planet Eclipse Geo3 Solenoid Replacement: Schritt 3, Bild 1 von 2 Planet Eclipse Geo3 Solenoid Replacement: Schritt 3, Bild 2 von 2
    • Pull the grip through the opening.
    • The grip is connected in the middle and is one piece.
  4. Planet Eclipse Geo3 Solenoid Replacement, Macroline: Schritt 4, Bild 1 von 3 Planet Eclipse Geo3 Solenoid Replacement, Macroline: Schritt 4, Bild 2 von 3 Planet Eclipse Geo3 Solenoid Replacement, Macroline: Schritt 4, Bild 3 von 3
    • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
  5. Planet Eclipse Geo3 Solenoid Replacement: Schritt 5, Bild 1 von 3 Planet Eclipse Geo3 Solenoid Replacement: Schritt 5, Bild 2 von 3 Planet Eclipse Geo3 Solenoid Replacement: Schritt 5, Bild 3 von 3
    • While pulling in the metal ring on the fitting, pull the macroline out.
  6. Planet Eclipse Geo3 Solenoid Replacement, Body: Schritt 6, Bild 1 von 3 Planet Eclipse Geo3 Solenoid Replacement, Body: Schritt 6, Bild 2 von 3 Planet Eclipse Geo3 Solenoid Replacement, Body: Schritt 6, Bild 3 von 3
    • Use 1/8" allen wrench to remove screw behind regulator.
  7. Planet Eclipse Geo3 Solenoid Replacement: Schritt 7, Bild 1 von 3 Planet Eclipse Geo3 Solenoid Replacement: Schritt 7, Bild 2 von 3 Planet Eclipse Geo3 Solenoid Replacement: Schritt 7, Bild 3 von 3
    • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
    • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
    • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
  8. Planet Eclipse Geo3 Solenoid Replacement, Solenoid: Schritt 8, Bild 1 von 3 Planet Eclipse Geo3 Solenoid Replacement, Solenoid: Schritt 8, Bild 2 von 3 Planet Eclipse Geo3 Solenoid Replacement, Solenoid: Schritt 8, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the 2 screws in the solenoid.
    • Remove the solenoid.
  9. Planet Eclipse Geo3 Solenoid Replacement: Schritt 9, Bild 1 von 1
    • Pry the board connection with the 2 black wires from the terminal.
    • BE CAREFUL: Do not pull hard by the wires or you may dislodge them from the connection instead of removing the connection from the board.
    • Pull out the wires through the opening in the top of the grip and replace the solenoid.
Abschluss
Rett Triplett
801 Reputation
8 Anleitungen geschrieben
Clemson, Team 13-6, Benson Fall 2013 Mitglied von Clemson, Team 13-6, Benson Fall 2013
CLEM-BENSON-F13S13G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 1,577
