Einleitung
This step-by-step guide is to help you replace an eye for a Planet Eclipse LV1 Paintball Marker. If the eye of a paintball marker is damaged or malfunctioning, the marker will not register that a paintball is loaded and will not shoot.
Before beginning, please turn off the paintball marker.
Was du brauchst
Remove the four grip screws with a 5/64" Allen wrench. There are two screws on each side of the marker.
On the non-battery side of the marker, unscrew the eye cover with a 5/64" Allen wrench to remove the eye cover.
On the battery side of the marker, unscrew the other eye cover with a 5/64" Allen wrench to remove the eye cover.
Pull the red and black eye sensor wires to disconnect the plug from the control board.
On the battery side of the marker, pull out the red eye sensor wire from the slot.
On the non-battery side of the marker, pull out the black eye sensor wire from the slot.
On the battery side of the marker, grasp the plug to remove the red and black eye sensor wires.
Orient the plug to align with the male receptors of the control board and click into place.
Grasp the black eye sensor wire and pull it completely through and out of the grip frame on the battery side.
Orient the sensor with the flat side facing up.
On the battery side of the marker, place the red eye sensor wire into the slot of the marker.
Set the eye cover into the slot and secure with the eye cover screw using a 5/64" Allen wrench.
On the battery side of the marker, push the black eye sensor wire through the grip frame and under the solenoid.
On the non-battery side of the marker, pull through the black eye sensor wire completely.
On the non-battery side of the marker, place the black eye sensor wire into the slot of the marker.
Secure the rubber grip with the four grip screws using a 5/64" Allen wrench. There are two screws on each side.
Thank you for viewing this step-by-step guide on replacing an eye for a Planet Eclipse LV1 Paintball Marker. Now get back out there and have fun!
