Zum Hauptinhalt wechseln
Einleitung
The following steps will teach you how to disassemble your headset and install a new microphone.
  1. Flip the headset face down. Squeeze both sides of the battery cover. While squeezing, pull the cover up slowly to remove it.
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Locate and detatch the white connector that connects the wires of the battery to the wires of the headset. Locate and detatch the white connector that connects the wires of the battery to the wires of the headset. Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
  3. Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components. Apply additional heat at the tip of the microphone.
    • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
    • Apply additional heat at the tip of the microphone.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset. Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
    • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
    • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
  6. Remove the microphone from the tip of the plastic. You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
    • Remove the microphone from the tip of the plastic.
    • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
  7. Use the heat gun to melt the adhesive connecting the headset face to the speaker casing. Use the plastic opening tool to separate the speaker casing from the headset face.
    • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
    • Use the plastic opening tool to separate the speaker casing from the headset face.
    • Add extra heat to the sides to melt the adhesive between the plastic connectors.
  8. Slowly separate the motherboard from the rest of the headset. Slowly separate the motherboard from the rest of the headset.
    • Slowly separate the motherboard from the rest of the headset.
  9. Locate the microphone wires on the bottom of the motherboard.
    • Locate the microphone wires on the bottom of the motherboard.
    • Use a hairdryer or heat gun to melt the glue off of the motherboard.
  10. Flip the device over.
    • Flip the device over.
    • Use a soldering iron to remove the solder that holds the wires to the motherboard.
    • For help soldering, click here.
    • The microphone piece should be completely detached from the motherboard.
Abschluss
To reassemble your device, follow these instructions in reverse order. Replace the glue and solder where they are needed.
Christopher Alfaro
22 Reputation
1 Anleitung geschrieben
Cal Poly, Team 17-29, Amido Spring 2012 Mitglied von Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 1,233
