Einleitung
This guide details the steps you'll need to disassemble and replace the battery in the Plantronics Voyager Focus. Here's the original thread that this guide comes from: Plantronics Voyager Focus B825 Battery Replacement
Was du brauchst
Begin by prying under the clear plastic, and you'll save the memory foam.
Start by lifting the top cover up.
Next, unscrew the two screws in the middle.
Lift up the next layer, and unscrew the 6 remaining screws here.
Often the battery will be stuck in with double-sided tape. If you struggle to take it out, try some isopropyl alcohol.
The battery is soldered in. Use a soldering iron and flux to disconnect it.
If you have a soldering iron and are holding it by the right end you’re in good shape.
All credit goes to this Q&A for the content for this.
Question:
Answer:
guy’s profile from Answer:
https://www.ifixit.com/User/3710612/jnes...
Question:
Answer:
5 weitere Nutzer:innen haben diese Anleitung absolviert.
