Zum Hauptinhalt wechseln
Plastic Phone Case Crack/Break Repair
Was du brauchst
    1. Plastic Phone Case Crack/Break Repair, Plastic Phone Case Crack/Break Repair: Schritt 1, Bild 1 von 3 Plastic Phone Case Crack/Break Repair, Plastic Phone Case Crack/Break Repair: Schritt 1, Bild 2 von 3 Plastic Phone Case Crack/Break Repair, Plastic Phone Case Crack/Break Repair: Schritt 1, Bild 3 von 3
      • Clean the cracked area of your phone case with a microfiber towel.
      Frag FixBot
      Kommentar hinzufügen
    2. Plastic Phone Case Crack/Break Repair: Schritt 2, Bild 1 von 2 Plastic Phone Case Crack/Break Repair: Schritt 2, Bild 2 von 2
      • Sand down the area until smooth.
      Frag FixBot
    3. Plastic Phone Case Crack/Break Repair: Schritt 3, Bild 1 von 3 Plastic Phone Case Crack/Break Repair: Schritt 3, Bild 2 von 3 Plastic Phone Case Crack/Break Repair: Schritt 3, Bild 3 von 3
      • Inject JB Weld epoxy into the provided mixing tray or a container of choice.
      • Use a disposable stick to mix the two elements into a homogeneous solution.
      Frag FixBot
    4. Plastic Phone Case Crack/Break Repair: Schritt 4, Bild 1 von 2 Plastic Phone Case Crack/Break Repair: Schritt 4, Bild 2 von 2
      • Use tape to hold the cracked or broken pieces firmly in place, ensuring the edges stay aligned maximizing contact.
      Frag FixBot
    5. Plastic Phone Case Crack/Break Repair: Schritt 5, Bild 1 von 3 Plastic Phone Case Crack/Break Repair: Schritt 5, Bild 2 von 3 Plastic Phone Case Crack/Break Repair: Schritt 5, Bild 3 von 3
      • Grab a small stick or any disposable tool.
      • Generously apply the mixed epoxy along the crack. Make sure to get some epoxy on the internal broken edges.
      Frag FixBot
    6. Plastic Phone Case Crack/Break Repair: Schritt 6, Bild 1 von 1
      • Once applied, wait 15 minutes for the epoxy to set.
      • Test epoxy strength.
      Frag FixBot
    7. Plastic Phone Case Crack/Break Repair: Schritt 7, Bild 1 von 1
      • Remove the tape holding the phone case together after the epoxy has cured for long enough for the bonded pieces to stay together.
      Frag FixBot
    8. Plastic Phone Case Crack/Break Repair: Schritt 8, Bild 1 von 2 Plastic Phone Case Crack/Break Repair: Schritt 8, Bild 2 von 2
      • Apply epoxy to other side of phone case crack.
      Frag FixBot
    9. Plastic Phone Case Crack/Break Repair: Schritt 9, Bild 1 von 3 Plastic Phone Case Crack/Break Repair: Schritt 9, Bild 2 von 3 Plastic Phone Case Crack/Break Repair: Schritt 9, Bild 3 von 3
      • Wait for 30 minutes for epoxy to cure fully before sanding.
      • Sand the bonded section until smooth.
      • Repeat on the inner side of phone case.
      Frag FixBot
Ziellinie
StephenH
169 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-6, Morris Spring 2025 Mitglied von UC Davis, Team 1-6, Morris Spring 2025
UCD-MORRIS-S25S1G6
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 35
Letzte 30 Tage: 146
Insgesamt: 1,284
