Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove all five screws on the downside of the PS2 Slimline Remove the "Do not void" seal carefully, underneath is the fifth screw located. Remove the "Do not void" seal carefully, underneath is the fifth screw located.
    • Remove all five screws on the downside of the PS2 Slimline
    • Remove the "Do not void" seal carefully, underneath is the fifth screw located.
  2. Make sure all screws are removed Caution with the seal, do not forget.
    • Make sure all screws are removed
    • Caution with the seal, do not forget.
    • Then take a metal sponger and open the chassis
  3. Locate the battery on the motherboard Use a metal spunger to peel it up Pull the cable and the battery is removed, ready to replace
    • Locate the battery on the motherboard
    • Use a metal spunger to peel it up
    • Pull the cable and the battery is removed, ready to replace
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
tlroesner
1.834 Reputation
4 Anleitungen geschrieben
2 Kommentare
why would i need to do this?
Dimitrios Frantzis - Antwort
To prior poster, you will not be able to effectively play certain types of games once the server is shut off by Sony.
Joe W. - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 27
Insgesamt: 9,247
