Einleitung
The Sony PlayStation 2 Slim relies on a CMOS battery, essentially a modified battery designed to power the CMOS chip in the hardware. This chip is responsible for storing boot settings, system time, and date. A faulty CMOS battery can cause faults in game saves, incorrect system time, or prevent the system from powering up.
Was du brauchst
Locate the battery on the motherboard. The battery will be a CR2032 Button Cell Battery
Carefully use a metal spudger to pull the battery out of the metal housing
Once the battery is fully removed, remove the connector upwards from the motherboard
6 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
why would i need to do this?
What do I replace the battery with? Can I re-apply the rubber casing of the original battery onto a new 2032 or what?
