Einleitung
This guide will show you how to locate and replace the fan in the PlayStation 2 Slimline.
Was du brauchst
Disconnect all cables from the console and flip the unit over to reveal its base.
Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
Gently lift and remove the fan from its compartment.
10 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Una disculpa ayuda es que lo arranque por accidente podría darme una ayuda
A
