Einleitung
This guide will walk you through step-by-step on how to properly remove and install the metal chassis in the PlayStation 2 Slimline.
Was du brauchst
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
Locate the fan component of the motherboard of the PS2.
With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
Detach the terminal (white covering) to the red and yellow cords from the motherboard to the fan with the use of tweezers.
Locate and unscrew the three 1.6mm screws located next to the base of the fan.
Once you have removed the three screws, you are able to remove the fan from the PS2.
Unscrew the four 4.0mm screws that mount the optical drive to the motherboard.
Using tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon to lift the black tab up on either side.
Locate the metal plate that is attached to the back of the motherboard.
2 weitere Personen haben diese Anleitung absolviert.
