Einleitung
This guide will walk you through step-by-step on how to properly remove and install the optical drive in the PlayStation 2 Slimline.
Was du brauchst
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon to lift the black tab up on either side.
14 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
I think that if the entire disc drive, assembled with a simple click in connection, would be much easier and faster.
