Einleitung
PlayStation 3 - How to replace Laser Lens and Mechanism (Laser Deck).
Please SUBSCRIBE to my channel ツ
More info about disassembling, you can find in
PlayStation 3 Slim Teardown
Einführungsvideo
  1. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. Remove Power Supply. Remove Power Supply. Remove Power Supply.
    • Remove Power Supply.
  3. Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive.
    • Separate cables, unscrew the screw and remove the Blu Ray drive.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Disassemble the upper metal shield. . Please SUBSCRIBE to my channel  ツ
  6. Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles.
    • Remove the two very small phillips screws in each lower corner referenced by the red circles.
  7. Be careful with flex cables. Be careful with flex cables. Be careful with flex cables.
    • Be careful with flex cables.
  8. Now you can remove the Laser Deck. Now you can remove the Laser Deck. Now you can remove the Laser Deck.
    • Now you can remove the Laser Deck.
  9. Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers.
    • Transfer two flex cables and 2x rubbers.
  10. You can test the console before full assembling. . Did you do it successfully?
Abschluss
12 weitere Nutzer haben diese Anleitung absolviert.
ZFix
162.377 Reputation
304 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
280 Mitglieder
783 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 5
Letzte 7 Tage: 36
Letzte 30 Tage: 164
Insgesamt: 16,009
