Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace your PlayStation 3 Slim's Bluetooth and Wi-Fi antennas.
  1. Turn the PS3 over and lay it on its backside.
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. Lift the top cover from its rear edge and rotate it toward the front of the PS3. Lift the top cover off the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  7. Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply. Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  8. Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  9. Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  10. Lift the power supply upward from its left edge as viewed from the front of the PS3.
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  11. Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture. Remove the power supply from the PS3, minding any cables that may get caught.
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  12. If present, remove the pieces of tape securing the antenna cables to the fan shroud, Blu-ray drive, and top shield. If present, remove the pieces of tape securing the antenna cables to the fan shroud, Blu-ray drive, and top shield.
    • If present, remove the pieces of tape securing the antenna cables to the fan shroud, Blu-ray drive, and top shield.
  13. Remove the two 6.2 mm Phillips screws securing the antennas to the lower case.
    • Remove the two 6.2 mm Phillips screws securing the antennas to the lower case.
  14. Use the flat end of a spudger to pry both antenna connectors up off their sockets on the motherboard. Use the flat end of a spudger to pry both antenna connectors up off their sockets on the motherboard.
    • Use the flat end of a spudger to pry both antenna connectors up off their sockets on the motherboard.
  15. Lift the antennas off their plastic positioning posts and remove them from the lower case, minding their cables that may get caught. Lift the antennas off their plastic positioning posts and remove them from the lower case, minding their cables that may get caught.
    • Lift the antennas off their plastic positioning posts and remove them from the lower case, minding their cables that may get caught.
Abschluss
16 weitere Nutzer haben diese Anleitung absolviert.
Do you guys have parts for PlayStation 3 Slim Antennas I want to now I can buy some from you guys
Edwin gomez - Antwort
Hi! i'm facing this 8002f1f9 error code and my ps3 is slim can you please help me out or suggest some troubleshootings.
Rafiq Gamrai - Antwort
Network adapter or joystick connection problem
Hyperion -
Which color is the wifi and which is the bluetooth? I haven’t tested the wifi on the system yet, but the controllers are not connecting so I think I have to replace just the bluetooth part.
optimusp517 - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 6
Past 7 Days: 46
Past 30 Days: 238
Insgesamt: 34,701
