Zum Hauptinhalt wechseln
PlayStation 3 Slim Top Cover Replacement
Was du brauchst
  1. PlayStation 3 Slim Top Cover Replacement, Top Cover: Schritt 1, Bild 1 von 1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim Top Cover Replacement: Schritt 2, Bild 1 von 2 PlayStation 3 Slim Top Cover Replacement: Schritt 2, Bild 2 von 2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim Top Cover Replacement: Schritt 3, Bild 1 von 1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim Top Cover Replacement: Schritt 4, Bild 1 von 1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim Top Cover Replacement: Schritt 5, Bild 1 von 2 PlayStation 3 Slim Top Cover Replacement: Schritt 5, Bild 2 von 2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
Abschluss
92 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
No good mine a Sony.
james register - Antwort
Thank you this helped me so much!!!!
Megan Davis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 80
Letzte 30 Tage: 303
Insgesamt: 73,183
