Zum Hauptinhalt wechseln
PlayStation 3 Wi-Fi/Bluetooth Board Replacement
Was du brauchst
  1. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Smart Plate: Schritt 1, Bild 1 von 2 PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Smart Plate: Schritt 1, Bild 2 von 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 2, Bild 1 von 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 3, Bild 1 von 3 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 3, Bild 2 von 3 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 3, Bild 3 von 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 4, Bild 1 von 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Top Cover: Schritt 5, Bild 1 von 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 6, Bild 1 von 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Memory Card Reader: Schritt 7, Bild 1 von 1
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  8. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 8, Bild 1 von 2 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 8, Bild 2 von 2
    • Lift the memory card reader out of the PS3 enough to access its cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the memory card reader from the PS3.
  9. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Wi-Fi/Bluetooth Board: Schritt 9, Bild 1 von 1
    • If necessary, peel the memory card reader ribbon cable off the Wi-Fi/Bluetooth board.
  10. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 10, Bild 1 von 1
    • Use the flat end of a spudger to pry the Wi-Fi antenna connector up from its socket on the Wi-Fi/Bluetooth board.
  11. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 11, Bild 1 von 2 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 11, Bild 2 von 2
    • Use your fingernail to flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket.
    • Pull the Wi-Fi/Bluetooth ribbon cable out of its socket.
  12. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 12, Bild 1 von 1
    • Remove the four 9 mm Phillips screws securing the Wi-Fi/Bluetooth board to the chassis.
  13. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: Schritt 13, Bild 1 von 1
    • Remove the Wi-Fi/Bluetooth board from the PS3, minding any cables that may get caught.
Abschluss
25 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Note: Only the first 2 generations of PS3 fats have removable Wifi/BT cards. If you have a third generation fat (VER-100 motherboard or later) the Wifi/BT chips are integrated into the board and thereby NOT removable.
Kevin Kwan - Antwort
does anybody know how many pins there are on the data ribbon / flex cable of the Wifi / Bluetooth board and Card Reader in the 60gb Model? It would be a great help! Thanx
yasien teladia - Antwort
I have a PS3 Slim 2501b can I still use this technique to change my Bluetooth
Kathleen Pereira - Antwort
No you can't
J P -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 92
Letzte 30 Tage: 459
Insgesamt: 115,159
