Einleitung
In this guide we are going to disassemble a playstation 3 controller.
Was du brauchst
Remove the five 7.2 mm Phillips screws at the back of the controller.
Separate the bottom case from the upper part. All the electronics stay in the upper part.
Unplug the battery from the PCB by using a pair of pliers as shown in the photo.
Remove all loose parts from the body. (Consisting of white rubber button underlays, black plastic buttons and a black rubber underlay for the start and select button.)
Remove the transparent plastic part covering the LED-lights by taking it out with a pair of pliers.
Remove the thin flexible green PCB by pulling out the black plastic circuit board cover, relatively in the middle the motherboard (the hard PCB) and by pressing click fingers on top of the motherboard.
Remove the thin flexible green PCB by lifting and pushing the two outer flaps.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
