Zum Hauptinhalt wechseln
PlayStation 4 CUH-1200 Entire Console Disassembly
Was du brauchst
  1. PlayStation 4 CUH-1200 Entire Console Disassembly, Unboxing the PS4 CUH-1200: Schritt 1, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Unboxing the PS4 CUH-1200: Schritt 1, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Unboxing the PS4 CUH-1200: Schritt 1, Bild 3 von 3
    • CUH-1200A Unboxing
  2. PlayStation 4 CUH-1200 Entire Console Disassembly, Let's get this thing torn down!: Schritt 2, Bild 1 von 1
    • The hard drive cover slides off just like on previous models.
  3. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Hard Drive: Schritt 3, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Hard Drive: Schritt 3, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Hard Drive: Schritt 3, Bild 3 von 3
    • The hard drive has one screw that needs to come out then it slides right out.
    • You'll need a PH 0 screwdriver for this step.
  4. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Warranty Stickers - Our Favorite Part!: Schritt 4, Bild 1 von 2 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Warranty Stickers - Our Favorite Part!: Schritt 4, Bild 2 von 2
    • Using a pick or something similar, peel off the warranty stickers to reveal two black T9 security torx screws.
    • Remove the two T9 security torx screws.
    • This is the first major revision we find...there are only two screws that hold the plastics on. The previous models had four.
  5. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Top Cover: Schritt 5, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Top Cover: Schritt 5, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Top Cover: Schritt 5, Bild 3 von 3
    • FIRST remove the two screws securing the top cover to the PS4. Removing the top cover will be easier if you follow these steps in order:
    • 1) Grab underneath of the top cover near the power button.
    • 2) Pull up...you will hear it click or snap as you pull up.
    • 3) Move your hand over to the opposite side of the top cover and pull up here as well.
    • 4) After puling up both sides of the top cover it should now slide back and off of the PS4.
    • We now have our first view of the inside of the CUH 1200. The first thing we notice is that the motherboard is much, much smaller and the APU clamp has been completely redesigned. The inside of this model is completely different than previous models.
  6. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Bottom Cover: Schritt 6, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Bottom Cover: Schritt 6, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Bottom Cover: Schritt 6, Bild 3 von 3
    • To remove the bottom cover you'll need to pull up very hard on each side of the cover near the back of the console.
    • You may be able to pull just with your hands but you might also need to use some opening tools to pry it off.
    • We get our first view of the components on the underside of the console. Looks like we have a redesigned power supply and optical drive.
  7. PlayStation 4 CUH-1200 Entire Console Disassembly, Notice the Buttons!: Schritt 7, Bild 1 von 2 PlayStation 4 CUH-1200 Entire Console Disassembly, Notice the Buttons!: Schritt 7, Bild 2 von 2
    • After we remove the bottom plastic we see the physical eject button that Sony has decided to use. This is another significant change over the previous models.
    • We're guessing this change is to help prevent the "random ejecting" of discs that plagued the previous models.
  8. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove the Power Supply: Schritt 8, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove the Power Supply: Schritt 8, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove the Power Supply: Schritt 8, Bild 3 von 3
    • Remove the three T9 torx screws then the two phillips PH 0 long screws.
    • Pull up on the left side (the side without the four wires), then on the right side. The right side of the power supply will be harder to pull up on so you'll need to pull firmly.
    • After you get it loose you'll be able to pull it up a bit but it will still be connected by the four wire connector so don't pull it all the way out until that has been disconnected (shown in the next step).
  9. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove the Power Supply Connector: Schritt 9, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove the Power Supply Connector: Schritt 9, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove the Power Supply Connector: Schritt 9, Bild 3 von 3
    • You'll need to disconnect this four wire connector from the motherboard.
    • The best way we've found is to use mini pliers. Pull up on one side then the other. Go back and forth one side at a time until it pops off.
    • The power supply can now be removed.
    • Use caution as this connector is easily pulled off the motherboard.
    • Be sure that you are pulling on the connector for the wires that go to the power supply itself and NOT on the connector on the motherboard.
  10. PlayStation 4 CUH-1200 Entire Console Disassembly, Disconnect Wifi Antenna and Optical Drive Cables: Schritt 10, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Disconnect Wifi Antenna and Optical Drive Cables: Schritt 10, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Disconnect Wifi Antenna and Optical Drive Cables: Schritt 10, Bild 3 von 3
    • Using the same pliers grasp the WiFi antenna cable and pull up carefully
    • The really wide optical drive cable has a black "collar" that needs to be lifted up on each side. This will free the cable.
    • The other two cables can just be pulled right out of their respective sockets.
  11. PlayStation 4 CUH-1200 Entire Console Disassembly, De-route and Remove WiFi Antenna: Schritt 11, Bild 1 von 2 PlayStation 4 CUH-1200 Entire Console Disassembly, De-route and Remove WiFi Antenna: Schritt 11, Bild 2 von 2
    • Remove the T9 security torx screw that secures the WiFi antenna.
    • De-route the WiFi cable.
  12. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Optical Drive: Schritt 12, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Optical Drive: Schritt 12, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Optical Drive: Schritt 12, Bild 3 von 3
    • Remove small ribbon cable from optical drive.
    • Remove five T9 security torx screws
    • Remove two PH 0 phillips screws along with the green PCB board.
  13. PlayStation 4 CUH-1200 Entire Console Disassembly, Optical Drive Notes: Schritt 13, Bild 1 von 2 PlayStation 4 CUH-1200 Entire Console Disassembly, Optical Drive Notes: Schritt 13, Bild 2 von 2
    • Even though the optical drive has been redesigned they still use the same roller system with the white bar in between. We're guessing that there will still be problems with these white bars falling out.
    • The laser and carrier look very similar to the previous models.
  14. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Top Metal Shield: Schritt 14, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Top Metal Shield: Schritt 14, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Top Metal Shield: Schritt 14, Bild 3 von 3
    • Remove twelve T9 security torx screws
    • Be careful to not lose the small metal nut under the black cover on the top left side. This nut is for one of the two long screws that hold the power supply that was removed in previous steps.
    • Remove six PH 0 phillips screws
    • Remove three PH 0 phillips screws
    • Pull the top metal shield off of the console.
  15. PlayStation 4 CUH-1200 Entire Console Disassembly, Motherboard Notes: Schritt 15, Bild 1 von 1
    • The first thing we notice (other than the size) about the motherboard is that Sony has totally re-designed the heat sink clamp. We're guessing (and hoping) this will reduce or eliminate the problem of PS4's turning on then back off.
  16. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Heat Sink Clamp and Power Button: Schritt 16, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Heat Sink Clamp and Power Button: Schritt 16, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Heat Sink Clamp and Power Button: Schritt 16, Bild 3 von 3
    • Remove the two PH 0 phillips screws.
    • After the clamp is removed the spacer under it will also need to be removed.
    • Remove the power button by prying up on the hook that's hooked into the motherboard.
    • After the hook is lifted the button will slide back and out.
  17. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Motherboard: Schritt 17, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Motherboard: Schritt 17, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Motherboard: Schritt 17, Bild 3 von 3
    • As you lift up on the front of the motherboard you will notice that the fan is still plugged in. This can be removed by grasping the connector with a pair of small pliers.
    • After that is removed the motherboard will lift out.
  18. PlayStation 4 CUH-1200 Entire Console Disassembly, Motherboard Notes: Schritt 18, Bild 1 von 2 PlayStation 4 CUH-1200 Entire Console Disassembly, Motherboard Notes: Schritt 18, Bild 2 von 2
    • We can now see one of the huge differences between the older models and this new model...there's no RAM on one side of the motherboard!
    • There is still the same amount of RAM but the total number of RAM chips has been cut in half.
    • In other news, the HDMI port has finally been redesigned! This is great news as the old style is very prone to failure.
  19. PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Fan: Schritt 19, Bild 1 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Fan: Schritt 19, Bild 2 von 3 PlayStation 4 CUH-1200 Entire Console Disassembly, Remove Fan: Schritt 19, Bild 3 von 3
    • Remove three PH 0 phillips screws then remove the metal piece.
    • With that gone there is only one screw (PH 0) holding the fan in. Remove it and you're done!
  20. PlayStation 4 CUH-1200 Entire Console Disassembly, Loose Piece Warning!: Schritt 20, Bild 1 von 2 PlayStation 4 CUH-1200 Entire Console Disassembly, Loose Piece Warning!: Schritt 20, Bild 2 von 2
    • As we started assembling this PS4 we noticed this small piece laying in on the bottom metal sheet. As we reassembled the console we found that it went on the top of the motherboard where one of the long power supply screws goes it. There is a black plastic piece that will cover it.
  21. PlayStation 4 CUH-1200 Entire Console Disassembly, Conclusion: Schritt 21, Bild 1 von 1
    • With this drastically different model of PS4 we are hoping that Sony has addressed some of the problems with the older models (HDMI port, etc). We are cautiously optimistic that they have.
Ziellinie
157 weitere Nutzer:innen haben diese Anleitung absolviert.
TronicsFix
34.802 Reputation
5 Anleitungen geschrieben
TronicsFix Mitglied von TronicsFix
Business
1 Mitglied
21 Anleitungen geschrieben
77 Kommentare
You didn't show what the supply connector is supposed to look like, when disconnected. Now I ripped it off of my mother board, attempting to assess milk damage. Thanks for helping me make sure my PS4 will stay broken.
draconicfeathers - Antwort
I'm so sorry it ripped off. I'm assuming you are talking about the power supply connector? If so step #10 shows the method we use to remove this connector. We use mini pliers and grasp one end at a time and pull up gently but firmly each time...this will eventually get the connector off without damage in most cases. That being said we have had to fix a connector every once in a while on these because some of them are fragile.
TronicsFix -
I ripped off my power supply from the motherboard too, assuming that from these photos that was where I was supposed to pull. Playstation is very broken now.
taylah.sewell -
Same here. I really don’t know what I’m supposed to do now.
Florent Krasniqi -
i dropped my ps4 and it made grinding noises when it reading discs and also it wouldnt eject disc, i fixed the eject problem by disassembling the blu ray drive but it still grinds when reading and only reads when i rebuild database. are you guys gonna start selling replacements anytime soon or will the blu ray from the cuh-11xx models work?
jer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 165
Letzte 7 Tage: 1,140
Letzte 30 Tage: 6,084
Insgesamt: 766,380
