Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Archiviert
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Archiviert
Einleitung
The official guide has been updated and can be found here. This guide is archived for historical purposes.
Provides step-by-step instructions on how to get to and remove hard drive, allowing user to replace hard drive.
Einführungsvideo
  1. Start by turning off your PS4 and unplugging the AC power cord. Slide the HDD bay cover (the top left portion of the console) to the left.
    • Start by turning off your PS4 and unplugging the AC power cord. Slide the HDD bay cover (the top left portion of the console) to the left.
  2. Remove the Hard Drive by unscrewing the single 5mm Phillips head #1 screw on the front left side of the PS4.
    • Remove the Hard Drive by unscrewing the single 5mm Phillips head #1 screw on the front left side of the PS4.
  3. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Slide the hard drive forward to remove it.
    • Slide the hard drive forward to remove it.
  5. Remove the four screws from the sides of the hard drive case. There are two identical screws on the opposite side.
    • Remove the four screws from the sides of the hard drive case. There are two identical screws on the opposite side.
  6. Remove the hard drive from the sleeve.
    • Remove the hard drive from the sleeve.
Abschluss
Robert Harvey
9.658 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 8-12, Regan Spring 2014 Mitglied von Cal Poly, Team 8-12, Regan Spring 2014
CPSU-REGAN-S14S8G12
5 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 6
Insgesamt: 19
